Schéma tertiaire : Chauffe-eau + contacteur
A remercié : 171 fois
A été remercié : 209 fois
VOici le schéma du chauffe-eau alimenté par un contacteur.
Le contacteur est commandé par un relais EDF.
<svg width="858" height="531" xmlns="http://www.w3.org/2000/svg" xmlns:xlink="http://www.w3.org/1999/xlink">
 <g>
  <title>Calque 1</title>
  <image x="112" y="172" width="48" height="217" id="svg_32" xlink:href="menus/branchement/Protections/Disjoncteur 2A.png"/>
  <image xlink:href="menus/branchement/Sources/alimentation.png" id="svg_4" height="54" width="408" y="0" x="0"/>
  <image xlink:href="menus/branchement/Protections/disjoncteur diff AC.png" id="svg_5" height="217" width="91" y="172" x="19"/>
  <image xlink:href="menus/branchement/Platine/PLEXO boite de derivation.png" id="svg_10" height="158" width="158" y="179" x="466"/>
  <line fill="none" stroke="#FF0000" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="53" y1="189" x2="53" y2="36.970398" id="svg_2"/>
  <line fill="none" stroke="#0000FF" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="31" y1="184.999999" x2="31" y2="85.920823" id="svg_3"/>
  <line fill="none" stroke="#0000FF" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="151" y1="36" x2="151" y2="86" id="svg_9"/>
  <line fill="none" stroke="#0000FF" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="29.000002" y1="86" x2="149.015747" y2="86" id="svg_11"/>
  <line fill="none" stroke="#0000FF" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="73" y1="187" x2="73" y2="140.956542" id="svg_12"/>
  <line fill="none" stroke="#0000FF" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="72" y1="140" x2="176.008336" y2="140" id="svg_14"/>
  <line fill="none" stroke="#FF0000" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="96" y1="185" x2="96" y2="156.982149" id="svg_15"/>
  <line fill="none" stroke="#FF0000" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="95" y1="157" x2="194.999997" y2="157" id="svg_17"/>
  <line fill="none" stroke="#33CC00" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="647.999996" y1="259" x2="386.988882" y2="259" id="svg_31"/>
  <image x="134" y="239" width="1" height="36" id="svg_60" xlink:href="menus/branchement/Protections/Disjoncteur 16A.png"/>
  <line fill="none" stroke="#FF0000" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="148" y1="157" x2="147" y2="185" id="svg_70"/>
  <image x="162" y="172" width="48" height="217" id="svg_68" xlink:href="menus/branchement/Protections/Disjoncteur 20A.png"/>
  <line fill="none" stroke="#FF0000" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="195" y1="158" x2="194" y2="186" id="svg_33"/>
  <line id="svg_35" y2="187" x2="176" y1="137" x1="176" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#0000FF" fill="none"/>
  <line id="svg_36" y2="190" x2="126" y1="140" x1="126" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#0000FF" fill="none"/>
  <image xlink:href="menus/branchement/Modulaires/contacteur.png" id="svg_37" height="217" width="48" y="172" x="243"/>
  <image xlink:href="menus/branchement/Modulaires/EDF.png" id="svg_38" height="217" width="48" y="228" x="798"/>
  <image xlink:href="menus/branchement/Recepteurs/chauffe eau.png" id="svg_39" height="313" width="150" y="4" x="682"/>
  <line id="svg_40" y2="498.015872" x2="146" y1="372" x1="146" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
  <line id="svg_41" y2="496" x2="436.060594" y1="496" x1="143" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
  <line id="svg_42" y2="273.489229" x2="435" y1="494" x1="435" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
  <line id="svg_43" y2="277" x2="536.046865" y1="277" x1="433" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
  <line id="svg_44" y2="513.00817" x2="536" y1="277.000002" x1="536" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
  <line id="svg_45" y2="512" x2="809.486251" y1="512" x1="533.999999" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
  <line id="svg_46" y2="514" x2="810" y1="429" x1="810" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
  <line id="svg_47" y2="492" x2="834" y1="429" x1="834" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#660099" fill="none"/>
  <line id="svg_48" y2="489" x2="543.848922" y1="489" x1="834.999991" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#660099" fill="none"/>
  <line id="svg_49" y2="264.980177" x2="546" y1="492" x1="546" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#660099" fill="none"/>
  <line id="svg_50" y2="268" x2="421.984001" y1="268" x1="547" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#660099" fill="none"/>
  <line id="svg_51" y2="487.002232" x2="424" y1="268.000004" x1="424" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#660099" fill="none"/>
  <line id="svg_52" y2="486" x2="254.763322" y1="486" x1="426" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#660099" fill="none"/>
  <line id="svg_53" y2="489.157786" x2="255" y1="375" x1="255" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#660099" fill="none"/>
  <line id="svg_54" y2="475.999998" x2="125" y1="371" x1="125" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#0000FF" fill="none"/>
  <line id="svg_55" y2="474" x2="277.108391" y1="474" x1="122" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#0000FF" fill="none"/>
  <line id="svg_56" y2="474.187312" x2="276" y1="375" x1="276" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#0000FF" fill="none"/>
  <line id="svg_57" y2="418.043458" x2="175" y1="372" x1="175" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#0000FF" fill="none"/>
  <line id="svg_58" y2="418" x2="220.010637" y1="418" x1="173" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#0000FF" fill="none"/>
  <line id="svg_63" y2="433.031243" x2="198" y1="372" x1="198" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
  <line id="svg_64" y2="432" x2="234.051248" y1="432" x1="195" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
  <line id="svg_71" y2="238.930456" x2="327" y1="354" x1="327" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
  <line id="svg_72" y2="240" x2="671.15382" y1="240" x1="325" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
  <line id="svg_73" y2="339.04368" x2="672" y1="239.000002" x1="672" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
  <line id="svg_74" y2="337" x2="730.031738" y1="337" x1="670.999999" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
  <line id="svg_75" y2="306" x2="728" y1="338" x1="728" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
  <line id="svg_77" y2="247.554458" x2="337" y1="360" x1="337" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#0000FF" fill="none"/>
  <line id="svg_78" y2="250" x2="662.079787" y1="250" x1="334.999994" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#0000FF" fill="none"/>
  <line id="svg_79" y2="350.077641" x2="661" y1="247" x1="661" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#0000FF" fill="none"/>
  <line id="svg_80" y2="347" x2="754.08244" y1="347" x1="659.999999" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#0000FF" fill="none"/>
  <line id="svg_81" y2="349" x2="752" y1="307" x1="752" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#0000FF" fill="none"/>
  <line id="svg_82" y2="366" x2="774" y1="308" x1="774" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#33CC00" fill="none"/>
  <line id="svg_83" y2="365" x2="648.963123" y1="365" x1="775" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#33CC00" fill="none"/>
  <line id="svg_84" y2="367.163515" x2="649" y1="257" x1="649" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#33CC00" fill="none"/>
  <line id="svg_85" y2="32.980177" x2="389" y1="260" x1="389" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#33CC00" fill="none"/>
  <line id="svg_62" y2="191.010868" x2="258" y1="147" x1="258" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#0000FF" fill="none"/>
  <line id="svg_61" y2="149" x2="259.102154" y1="149" x1="215" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#0000FF" fill="none"/>
  <line id="svg_59" y2="147.909609" x2="216" y1="419" x1="216" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#0000FF" fill="none"/>
  <line id="svg_76" y2="360" x2="338.146932" y1="360" x1="253" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#0000FF" fill="none"/>
  <line id="svg_69" y2="351" x2="329.009432" y1="351" x1="279" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
  <line id="svg_67" y2="189.068884" x2="278" y1="160" x1="278" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
  <line id="svg_66" y2="162" x2="279" y1="162" x1="229" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
  <line id="svg_65" y2="159.816239" x2="231" y1="432" x1="231" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
 </g>
</svg>
Re: Schéma tertiaire : Chauffe-eau + contacteur
Remis à jour.
chauffe eau.rar
(2.01 Kio) Téléchargé 295 fois
Bah, super !!!
mais t'es en vacances pour faire tout ça ?
OUI pas mal jolie boulot
Non, c'est mercredi et madame est occupée.
En plus il fallait que je face la correction du dossier chauffage de Christophe pour mes élèves.
