Schéma tertiaire : double allumage
A remercié : 172 fois
A été remercié : 209 fois
Voici le schéma du double allumage. Les lampes peuvent être remplacées par des prises de courants.
<svg width="766" height="555" xmlns="http://www.w3.org/2000/svg" xmlns:xlink="http://www.w3.org/1999/xlink">
 <g>
  <title>Calque 1</title>
  <image x="0" y="44" width="408" height="54" id="svg_1" xlink:href="menus/branchement/Sources/alimentation.png"/>
  <image x="0" y="164" width="91" height="217" id="svg_2" xlink:href="menus/branchement/Protections/disjoncteur diff AC.png"/>
  <image x="90" y="164" width="48" height="217" id="svg_3" xlink:href="menus/branchement/Protections/Disjoncteur 16A.png"/>
  <image x="582" y="0" width="86" height="238" id="svg_5" xlink:href="menus/branchement/Recepteurs/lampe fluo.png"/>
  <image x="358" y="218" width="158" height="158" id="svg_7" xlink:href="menus/branchement/Platine/PLEXO boite de derivation.png"/>
  <line fill="none" stroke="#FF0000" stroke-width="5" x1="35" y1="177" x2="35" y2="112.968758" id="svg_8"/>
  <line fill="none" stroke="#FF0000" stroke-width="5" x1="15" y1="82" x2="15" y2="117.128336" id="svg_10"/>
  <line fill="none" stroke="#FF0000" stroke-width="5" x1="38" y1="115" x2="13" y2="115" id="svg_13"/>
  <line fill="none" stroke="#FF0000" stroke-width="5" x1="124" y1="176" x2="124" y2="142" id="svg_15"/>
  <line fill="none" stroke="#FF0000" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="78" y1="141" x2="126" y2="141" id="svg_16"/>
  <line fill="none" stroke="#FF0000" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="81" y1="141" x2="80" y2="179" id="svg_17"/>
  <line fill="none" stroke="#0000FF" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="10" y1="180" x2="10" y2="124.99091" id="svg_18"/>
  <line fill="none" stroke="#0000FF" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="8" y1="127" x2="152.170038" y2="127" id="svg_19"/>
  <line fill="none" stroke="#0000FF" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="150" y1="127" x2="150" y2="78.958351" id="svg_20"/>
  <line fill="none" stroke="#0000FF" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="55" y1="175" x2="55" y2="148.980776" id="svg_21"/>
  <line fill="none" stroke="#0000FF" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="104" y1="178" x2="104" y2="150.981488" id="svg_22"/>
  <line fill="none" stroke="#0000FF" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="53" y1="151" x2="107.009258" y2="151" id="svg_24"/>
  <line fill="none" stroke="#0000FF" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="102" y1="364" x2="102" y2="509.013792" id="svg_27"/>
  <line fill="none" stroke="#0000FF" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="100" y1="508" x2="313.009389" y2="508" id="svg_28"/>
  <line fill="none" stroke="#0000FF" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="310" y1="506" x2="310" y2="276.997536" id="svg_29"/>
  <line fill="none" stroke="#0000FF" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="307" y1="276" x2="628.001577" y2="276" id="svg_31"/>
  <line fill="none" stroke="#0000FF" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="627" y1="276" x2="627" y2="237.999998" id="svg_32"/>
  <line fill="none" stroke="#FF0000" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="124" y1="366" x2="124" y2="497.308796" id="svg_33"/>
  <line fill="none" stroke="#FF0000" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="123" y1="494" x2="298.139944" y2="494" id="svg_36"/>
  <line fill="none" stroke="#FF0000" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="298" y1="291" x2="298" y2="496.02195" id="svg_38"/>
  <line fill="none" stroke="#FF0000" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="296" y1="294" x2="420.004032" y2="294" id="svg_39"/>
  <line fill="none" stroke="#FF0000" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="529" y1="459" x2="416" y2="459" id="svg_41"/>
  <line fill="none" stroke="#FF0000" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="418" y1="458" x2="418" y2="293.923798" id="svg_42"/>
  <line fill="none" stroke="#000000" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="526" y1="430" x2="430.994737" y2="430" id="svg_43"/>
  <line fill="none" stroke="#000000" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="612" y1="292" x2="433.974721" y2="292" id="svg_49"/>
  <line fill="none" stroke="#000000" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="433" y1="429" x2="433" y2="290.996317" id="svg_50"/>
  <line fill="none" stroke="#33CC00" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="286" y1="76" x2="286" y2="286.047881" id="svg_51"/>
  <line fill="none" stroke="#33CC00" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="284" y1="284" x2="646.00929" y2="284" id="svg_52"/>
  <line fill="none" stroke="#33CC00" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="646" y1="285" x2="646" y2="233.967749" id="svg_56"/>
  <image xlink:href="menus/branchement/Commandes/double interrupteur.png" id="svg_4" height="129" width="129" y="409" x="513"/>
  <line id="svg_6" y2="552.085982" x2="503" y1="459" x1="503" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
  <line id="svg_9" y2="549" x2="655.013071" y1="549" x1="502" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
  <line id="svg_11" y2="457" x2="657.052597" y1="457" x1="621" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
  <line id="svg_12" y2="454.978497" x2="654" y1="548" x1="654" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
  <line id="svg_14" y2="430" x2="659.013511" y1="430" x1="622" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#660099" fill="none"/>
  <line id="svg_23" y2="401.560035" x2="447" y1="315.000001" x1="447" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#660099" fill="none"/>
  <line id="svg_25" y2="397.933407" x2="655" y1="428" x1="655" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#660099" fill="none"/>
  <line id="svg_26" y2="401" x2="655.02153" y1="401" x1="446" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#660099" fill="none"/>
  <line id="svg_30" y2="317" x2="704.123048" y1="317" x1="444" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#660099" fill="none"/>
  <line id="svg_34" fill="none" stroke="#0000FF" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="723" y1="304" x2="723" y2="235.999997"/>
  <line id="svg_35" fill="none" stroke="#33CC00" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="745" y1="308" x2="745" y2="234.967751"/>
  <image id="svg_40" x="680" y="1" width="86" height="238" xlink:href="menus/branchement/Recepteurs/lampe fluo.png"/>
  <line id="svg_44" fill="none" stroke="#33CC00" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="440" y1="310" x2="747.009293" y2="310"/>
  <line id="svg_37" y2="235.9334" x2="703" y1="317.000001" x1="703" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#660099" fill="none"/>
  <line id="svg_45" fill="none" stroke="#0000FF" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="464.999997" y1="302" x2="723.001572" y2="302"/>
  <line id="svg_46" fill="none" stroke="#0000FF" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="467" y1="304" x2="467" y2="274.997529"/>
  <line id="svg_47" fill="none" stroke="#33CC00" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="444" y1="310.000001" x2="444" y2="280.967746"/>
  <line fill="none" stroke="#000000" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="607" y1="233.999999" x2="607" y2="295.331043" id="svg_48"/>
 </g>
</svg>
Retourner vers « Schémas électriques »
