Schéma tertiaire : Montage Volets roulants
A remercié : 171 fois
Voici le schéma de principe d'un montage pour volets roulants :
<svg width="858" height="566" xmlns="http://www.w3.org/2000/svg" xmlns:xlink="http://www.w3.org/1999/xlink">
 <g>
  <title>Calque 1</title>
  <image x="0" y="0" width="408" height="54" id="svg_4" xlink:href="menus/branchement/Sources/alimentation.png"/>
  <image x="20" y="172" width="91" height="217" id="svg_5" xlink:href="menus/branchement/Protections/disjoncteur diff AC.png"/>
  <image x="118" y="170" width="48" height="217" id="svg_6" xlink:href="menus/branchement/Protections/Disjoncteur 16A.png"/>
  <image x="426" y="182" width="158" height="158" id="svg_10" xlink:href="menus/branchement/Platine/PLEXO boite de derivation.png"/>
  <line id="svg_2" y2="36.970398" x2="53" y1="189" x1="53" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
  <line id="svg_3" y2="84.920823" x2="31" y1="186" x1="31" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#0000FF" fill="none"/>
  <line id="svg_9" y2="86" x2="151" y1="36" x1="151" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#0000FF" fill="none"/>
  <line id="svg_11" y2="86" x2="150.015747" y1="86" x1="30.000002" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#0000FF" fill="none"/>
  <line id="svg_12" y2="140.956542" x2="73" y1="187" x1="73" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#0000FF" fill="none"/>
  <line id="svg_13" y2="139" x2="132" y1="183" x1="132" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#0000FF" fill="none"/>
  <line id="svg_14" y2="140" x2="132.008333" y1="140" x1="72" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#0000FF" fill="none"/>
  <line id="svg_15" y2="156.982149" x2="96" y1="185" x1="96" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
  <line id="svg_16" y2="153.983338" x2="147" y1="184" x1="147" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
  <line id="svg_17" y2="157" x2="147" y1="157" x1="95" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
  <line id="svg_18" y2="408.051248" x2="153" y1="369" x1="153" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
  <line id="svg_20" y2="405" x2="338.002688" y1="405" x1="152" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
  <line id="svg_22" y2="265.773183" x2="336" y1="404" x1="336" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
  <line id="svg_23" y2="424.009613" x2="133" y1="370" x1="133" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#0000FF" fill="none"/>
  <line id="svg_24" y2="422" x2="351.058398" y1="422" x1="134" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#0000FF" fill="none"/>
  <line id="svg_25" y2="255.728438" x2="348" y1="417" x1="348" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#0000FF" fill="none"/>
  <line id="svg_27" y2="423" x2="348" y1="412" x1="348" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#0000FF" fill="none"/>
  <line id="svg_35" y2="480" x2="558.365697" y1="480" x1="493.000003" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
  <line id="svg_38" y2="506" x2="562.000002" y1="506" x1="506.000002" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#660099" fill="none"/>
  <line id="svg_39" y2="509.052626" x2="508" y1="262.999981" x1="508" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#660099" fill="none"/>
  <line id="svg_44" y2="266.033709" x2="495.069214" y1="266.033709" x1="334.999998" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
  <line id="svg_45" y2="265.103758" x2="492" y1="482.000011" x1="492" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
  <image xlink:href="menus/branchement/Recepteurs/Volet roulants.png" id="svg_85" height="159" width="227" y="87" x="627"/>
  <line id="svg_87" y2="450" x2="519" y1="450" x1="556" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#993300" fill="none"/>
  <line id="svg_88" y2="272.523241" x2="521" y1="450" x1="521" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#993300" fill="none"/>
  <line id="svg_89" y2="254" x2="662.191386" y1="254" x1="346.000007" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#0000FF" fill="none"/>
  <line id="svg_90" y2="258.039816" x2="663" y1="145" x1="663" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#0000FF" fill="none"/>
  <line id="svg_91" y2="264" x2="622.069544" y1="264" x1="505.999999" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#660099" fill="none"/>
  <image xlink:href="menus/branchement/Commandes/BP volet.png" id="svg_86" height="129" width="129" y="429" x="543"/>
  <line id="svg_92" y2="274" x2="603.05486" y1="274" x1="521" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#993300" fill="none"/>
  <line id="svg_93" y2="371" x2="705" y1="372" x1="705" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
  <line id="svg_94" y2="101" x2="599.968262" y1="101" x1="663" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#993300" fill="none"/>
  <line id="svg_95" y2="98.928176" x2="600" y1="273" x1="600" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#993300" fill="none"/>
  <line id="svg_96" y2="122.715075" x2="619" y1="265" x1="619" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#660099" fill="none"/>
  <line id="svg_97" y2="121" x2="614.618569" y1="121" x1="662" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#660099" fill="none"/>
  <g id="svg_101">
   <ellipse ry="7.5" rx="7.5" id="svg_98" cy="100.05056" cx="712.252808" stroke-linecap="null" stroke-linejoin="null" stroke-width="3" stroke="#000000" fill="none"/>
   <line id="svg_99" y2="91.86518" x2="714.471914" y1="104.786529" x1="706.044947" stroke-linecap="null" stroke-linejoin="null" stroke-width="3" stroke="#000000" fill="none"/>
   <line id="svg_100" y2="94.674169" x2="718.966296" y1="107.595517" x1="710.539329" stroke-linecap="null" stroke-linejoin="null" stroke-width="3" stroke="#000000" fill="none"/>
  </g>
  <text font-weight="bold" transform="matrix(0.5880149602890015,0,0,0.5880149602890015,100.52434968948364,54.38202524185181) " xml:space="preserve" text-anchor="middle" font-family="Sans-serif" font-size="24" id="svg_102" y="85.996716" x="1064.60795" stroke-linecap="null" stroke-linejoin="null" stroke-width="0" stroke="#000000" fill="#000000">T</text>
  <line stroke-width="5" id="svg_103" y2="244.787129" x2="391.43821" y1="35.685405" x1="391.43821" stroke-linecap="null" stroke-linejoin="null" stroke="#33CC00" fill="none"/>
  <line id="svg_104" y2="242.426982" x2="589.772435" y1="242.426982" x1="388.629221" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#33CC00" fill="none"/>
  <line id="svg_105" y2="79.754973" x2="586.943832" y1="243.550577" x1="586.943832" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#33CC00" fill="none"/>
  <line id="svg_106" y2="78.943833" x2="713.408683" y1="78.943833" x1="585.258438" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#33CC00" fill="none"/>
  <line id="svg_107" y2="96.367154" x2="711.662935" y1="75.573046" x1="711.662935" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#33CC00" fill="none"/>
 </g>
</svg>
